Ah, allright, thanks!
I did exchange the output pot to a new stepped switch reading 1K, double checked all the wiring, resoldered the input put.
The unit works - on one channel.
I made you guys a video:
http://we.tl/TVpoB5Rti5
You only hear one channel at once.
First, you will hear the left channel. This is the bad one. On 0:10 for example you can see and hear, how the compression bangs in with a THUMP, then only very slowly returns.
After that, i switched to the right side. This side sounds better and reacts very fast, off course depending on the setting.
I did switch back and forth the Input Pot, Recovery + Mode switch, Input tranny and most of the tubes from the good and the bad channel, to rule them out as causes for the problem.
