Hi all,
Fabio mentioned a few weeks back that the schem and BOM listed previously on this thread (the link says rev2, but the schematic says rev1) does not include some of the changes he made for these boards. Stay posted and he'll update.
Also, the PS/filter section is on the board, so no need for separate power supply. If you do two comps in one box, you can fill the PS filter section of one board, then jumper it to the 2nd board. So you can leave off one PS section worth of parts for one box with 2 Whats. You'll still need a 2x15v/30va toroid off-board.
BTW, Kir-For-Pleasure, BOM = Bill of Materials, that's the parts list you were asking about. The link is earlier in the thread. Not sure if this (rev1) BOM includes parts for the opamps (or any special features Fabio added), but I don't think so. There's another link to a parts list for the 1731 on Fabio's site (DIY Pill).
Added to Martin's cap info: make sure whatever caps you use will actually fit on the boards. Some film caps are much bigger than others, like 21mm across instead of 7mm. And sometimes the higher voltage (like 10u35 instead of 10u16) electrolytic caps are too big... other times they're fine. So it's good to measure the space allowed on the board, then look in the catalog or data sheet for the cap's 'package size' to make sure it's usable. Also, "Low ESR" types can be good for electrolytics.
Hope it helps, Paul
