C1 should be very low microphonic, very low leakage capacitor, what an old ceramics aren't.
And, if one mic worth USD10k, I don't see any problem with expensive parts inside.
C1 is the backplate grounding cap, 10nF. Yes, it forms a LPF with the polarising resistor R1, which is 100M. Corner freq is 0.2Hz. Who cares what the -3dB point is?
It is, however, directly in the audio path. Dielectric will affect audio quality.
precisely, guys!The difference is small. But it is, it is exactly. I hear a slight compression on High frequencies, which I really like in sound with paper capacitor. I want to explain why using D#####d, not other paper capacitors. It's not as bulky as other modern PIO caps. Modern technology allows to avoid leakage, which has always been characteristic of the most of old PIO caps. Also D#####d very reliable and stable when operating at high temperatures. It has very little distortion factor. It would be interesting to try it as C3, but 1uf is too bulky even for long body.
p.s Many famous modern companies ignore the small differences that make capacitors. Capacitors always affect the sound. Therefore, modern microphones (u47 clones) often sound brighter. Most people like it, but not all.
