thor.zmt
@thor.zmt this is really impressive. I went “wow, -115!” a few posts back and “these concepts should get put together,” and then you did it. This is publishable research.
Well, to me this is mostly "old hats".
Trying to avoid asking any dumb questions here. I don’t have a strong background in discretes, so i’m having a hard time following the way the noise servos work without all the values. Are they just not showing up?
I deliberately hid them. Many people these days are not good with anything not involving triangles with +/-/Out. I do not want to provide ready designs to chinese kopy katz. Anyway, anyone who cannot calculate these should do some remedial...
The noise servo uses a Sziklai or "Compound Feedback Pair". It has also been called "inverted darlington".
In effect the second transistor increases the transconductance of the first one.
The first transistor runs at ~0.5mA collector current and thus has ~ 52 Ohm emitter resistance.
If we ignore base resistance and source resistance this determines the transconductance of the first transistor. A change of 1mV will produce a change of 19uA.
The second transistor runs at ~1.5mA collector current and thus has ~17 Ohm emitter resistance. It also has as a result of a fairly high beta an input impedance of around 5kOhm and the base emitter resistor is 1.2kOhm.
In parallel we get almost exactly 1k, so 19uA change in 1kOhm give 19mV input voltage which, when divided by the 17 Ohm emitter resistance gives around 1mA current change. The circuit also forms a near constant current sink for the first transistor, which now operates at (almost) constant current.
So the "open loop" transconductance of this compound transistor is 1mA/1mV or 1A/!V or 1 Siemens. This means als that the "virtual" emitter impedance of the transistor is 1 Ohm.
Adding a further resistor (in the schematic R8/R19) reduces transconductance and linearises the Transconductance. Bu using a cascode transistor (T5) the whole compound pair also operates at (almost) constant voltage, making it more linear again.
At the same time also the signals from the two separate noise (reduction) amplifiers (one for each Op-Amp) are summed.
The collector of T5 now has a current that is modulated in accordance to the base voltage variations of the first transistor in the two noise amplifiers and it has very high impedance (many MOhm). The circuit is inherently inverting.
The input to the circuit is the inverting input of the Op-Amp.
We are being told that this is a "virtual ground". That is a first order oversimplification that is only true for a "super-ideal" Op-Amp with infinite gain, bandwidth and zero ohm output impedance.
In fact, with a real Op-Amp, even assuming absolutely identical resistors in the inverter, the output will never be exactly Vin * -1. Noise and distortion will make the output different. If so, the noise and distortion must appear on the inverting input. And it is of course amplified, giving the 6dB noise gain of the inverting circuit.
Our Noise (reduction) amplifier simply takes this noise and distortion as it's input signal and converts it into a current of inverse polarity with a certain fixed factor of conversion (~ 62mA/V here).
As said, the current eventually exist the collector of T5 which has a 2.7kOhm resistor to the negative rail to provide 4mA supply current. There is also a 5.1kOhm resistor (and a DC blocker capacitor) to the output, which we can see as 50 Ohm to ground (without signal).
The inverted noise current is now applied to this resistive network (Kirchoff remedial recommended) and produces a voltage across the 5.1k & 2.7k resistors. This voltage in turn causes a current flow in the 5.1kOhm resistor that also enters the load and more crucially the two 100 Ohm build out resistors on the Op-Amp's.
If we have all gains correct and just so, the inverted noise current through the 5.1k resistor produced a noise voltage across the 100 Ohm resistors that when summed with the noise voltage of the Op-Amp nulls out. The same should incidentally happen to any harmonic distortion.
Of course, the Noise (reduction) Amp has it's own noise and distortion, so nulling is imperfect.
The concept is also know as "Error Takeoff" and has been in public domain since the 80's.
If the error "taken off" is not inverted and mixed into the actual inverters output, but instead is buffered, scaled and then mixed into the non-inverting output (or rather cross-coupled between two inverting circuits with a balanced input we get the (not) world famous Jikoda Circuit, named after the japanese "just in time" concept "jidoka" (じどうか)
- Detect the abnormality.
- Correct the immediate abnormality "just in time".
Do I understand correctly that the same concept could be applied to any inverter, and that values are pretty widely scalable as long as the injection ratio matches the Sziklai pair gain?
Essentially yes. But the noise (reduction) amplifier needs "design in".
If the noise sample comes from the inverting input of a diff amp that is being relied upon for CMR,
It does not really work. For that go FDA and noise-reduce both sections or go jikoda.
I saw that you spec’d your original transistor choices and then they went away and am wondering what the factors are in parts choice as you figure this out.
Protecting trade secrets. The input transistor must offer low noise and high beta, not many options that are readily available exist. The second stage needs even higher beta and still low noise.
It would be pretty cool to see this architecture surrounding a solitary LME49724 in a diff-to-diff context.
Yes, that would be a good application.
Not a big difference between 2.1nV/rtHz and the 1.1nV/rtHz of the OPA1612, and it’s on the cheap side. Also note that the 1.1nV/rtHz (!) OPA1633 is in preview; there must be a model available.
Sure, but I ask again, why not just go impedance balanced for line outs? And why not use a discrete line driver that can be made to run on +/-24V, with minimal distortion and noise at a fraction of the cost of a comparable Op-Amp in a can?
Never mind the bragging rights of "+/-24V Class A discrete line driver" in my Gizmo?
Just saying.
Or take a 5534, hang a class P-P stage of Pin 5 with a bootstrapped resistor pair to +V to give the second VAS Transistor a few mA extra current to increase transconductance.
And let's replace the input pair by a Toshiba dual J-Fet with ~1.5nV|/Hz (~ 2nV |/Hz for the full differential pair, 27 cent US if buying 3,000pcs reels from Mouser) and up the input current and second stage differential current a good deal.
I think that is much more fun, never mind performance.
Thor
