Link?You must read about it.
52V pp is 26.5V peak, which is 42.5mA into 600R, easily within the 85mA current limit.If the LME49724 can put out 52Vpp into 600R (86.7mA), and its short circuit current is 85mA
PP is as trap in this stuff as it means NOTHING at any given time, the thing is never outputting 52V, cannot output 52V and will not output 52V,
Power dissipation might be an issue with these very extreme levels, but the saving grace is likely that they are not sustained, still need to look at SOA curves possibly.
What’s SOA?
Nope, 19.8V pk looks sane, call it 20V, so each opamp is outputting +-10V at peak.
So harkening back to my 3-amp OPA2210 + OPA210 FDA driving 440R when all is said and done into, say, a vintage 1176:
14Vrms aka 25.1dBu / .70707 = 19.8Vpk
19.8Vpk / 440R = 45mA differential
45mA / 2 = 22.5mA per side
45mA * 19.8Vpk = 891mW dissipation from the dual op amp
Correct?
What’s SOA?
Any particular reason as to why you used a Diamond Buffer? I've never found a sufficiently good reason to use it as opposed to more conventional configurations with the good old bias spreader.
Got it. I had edited the last post to ask just that while you were writing - and now D’s Kirchhoff reference makes sense. I also added the sourcing/sinking graphs and thermal info for this amp in case anyone has anything to glean from those. 45mA wouldn’t work at 125deg C but below 85deg C it looks plausible, given maybe a THD increase.Nope, 19.8V pk looks sane, call it 20V, so each opamp is outputting +-10V at peak.
Current is 45mA and is being sourced by one opamp and sunk by the other, you do not get to divide this by two!
Ohhhhhhhh. OK.Now if you are driving into a resistive load (Not a given with old gear) then at peak and assuming a +-15V power rail, each opamp is dropping 5V (10V ouptut, 15V supply rail) at 45mA, so is dissipating 225mW *2 (There are two opamps), so 450mW.
I will have to grok this.However this may not be worst case as a lower output voltage may actually increase dissipation because the voltage dropped across the opamp output transistor will be increased (Try it with a 15V Pk output and see what you get!). The pathological case is driving an inductor where the current is 90 degrees out of phase and hence voltage across the opamp output transistor and current thru it hit maximum at the same time.
I’ve been assuming 50deg C inside a well designed but tight and unventilated compact piece of gear.SOA stands for safe operating area, it is a graph with voltage on one axis and current on the other that describes the combinations that a transistor can survive (Note, voltage is voltage across the device, not anything else). They are notoriously published at unrealistically low temperatures (20c typically).
No. Each side provides 45mA. When one pushes, the other pulls14Vrms aka 25.1dBu / .70707 = 19.8Vpk
Consider this line driver. It’s a +/-14dB differential trim, but I’ve simplified it here to just show minimum feedback current, ie a gain of 5.
In the 600 ohm load scenario, ignoring cable length:
- U1 differentially drives 5K, 5K, 5K, 5K, and 678R. That’s ~440R.
- 39.6Vpp into 440R is ~90mA
I’m still interested in seeing the Birt forms we were discussing upthread, there are certainly applications, and would love to see whatever you’ve got on that. The additional loading of driving the inverter with the diff amp is a bit of a hurdle. Your note on what happens with its noise (turning into CM noise) was elucidating. The only issue with adding to CM noise on….well, any insert or output that shows up on a patchbay…is that you can’t necessarily rely on the receiver to have excellent CMR.Not sure what you are trying to achieve? Compatibility with a SE input? I think Birt is a better choice.
Just noticed that you simulator claims around 0.000003% THD, and only 2nd harmonic, did you ever measure THD on the real deal? and, if so, how was it?I normally agree. The Diamond buffer is selected as we need a lot of drive for high levels into 600 Ohm.
That mean a simple EF will not cut it. I dislike EF2 (or EF3) plus Bias Spreader, thermal stability is problematic.
Diamond (instead of EF2) or Diamond fronted CFP (instead of EF3) are able to do a lot of heavy lifting at low HD and with correctly designed layout exceptional thermal stability.
I do have other options, but I like to keep some stuff for myself.
Thor
I forgot to multiply by a hundred to get it in percentage. Your plot says -90 for the 2nd harmonic and 20 for the fundamental, I am guessing those are decibels? There is also no other harmonic present that I can see, so the entire distortion is produced by that 2nd harmonic, that means the distortion is -110 dB below the fundamental, or 0.0003%, which is not bad at all.Nope, it claims -134dB (-110dBV on +24dBV Signal) or 0.00002% H2. Now we are likely to see upper harmonics.
I have done so on other circuits, usually the match is quite close.
Thor
I've posted an article here on the many uses of the versatile Birt FDA
So it’s good that i’m building a system around 15V dual instead of 18V dual. From a thermal perspective at the PCB (the supply being a different story!), it sounds like you wanna use the lowest rail you can get away with while keeping amps in their optimal headroom range. Using 7Vrms (19dBu) per side as a standard instead of 10Vrms (22dBu), in conjunction with amps that run reasonably close to RRIO under reasonably hefty loading, might open up the use of 12V dual for me. And that also explains the zillions of impedance balanced 5534 outputs in existence that run on 24V single.The power dissipation actually increases as you LOWER the signal amplitude peaking at 1/2 the supply voltage (so 7.5V) before falling again,
Now that’s a distribution amp!I have seen a D/A card (Drake?) done with a pair of TDA2030 driving a fairly large number of Lundhal transformers for the outputs, which I thought was a fun, if expensive approach.
