[quote author="soundguy"]definitely an external powersupply. Id like to potentially build a mixer and dont need a power transformer in the box with my unshielded mix busses.[/quote]
This is where I'm heading as well......just leave power headers on the main boards which can be fed from internal or external PSUs.
gus, the board should be able to fit in a par metal case, I think that gives us 7" orr 8" deep
Although not all of us are based in the US and can get hold of Par-Metal cases. I'll get dimensions for a bunch of diff cases so we can find a size that fits all. I see nothing wrong with a pair of eurocards like Jakob's CalrecEQ.
We've got to make it work with a lorlin switch. If this means less gain steps and a wider fader swing between steps, so be it.
Well, I sort of agree - I like Brians suggestions for the front end, 12 pos gain and trims....but I don't think we can make it work with Lorlins without severe simplification.
If the cheap lorlins dont offer enough contacts to do all the bands in the EQ, we are going to have to leave some off.
NSF also do modular switches which are cheap, available from Farnell and flexible.
I really don't see the point in PCB mounting Lorlins though, its only a 'little' bit of P-to-P and shouldn't add drastically to the cost. The gain switch is most probably going to need to be something other than a Lorlin as they dont offer enough contacts. The project would still be affordable if it was Grayhill gain and Lorlin everything else.
Once we get a green light on the inductors, the way I look at this, in order for this tremendous amount of work to be worth doing at all is to bring this project in as inexpensively as possible.
If the inductor issue isn't sorted we cannot go any further with this than a micpre and to be fair there are loads of good micpre project here already. The EQ is the interesting part for me.
As a project it should be much cheaper than the 1081. 1081 uses loads more iron, complex concentric switches and original knobs that are very expensive.
However, the 1061 even with input and output iron plus a custom run of MF inductor would still be a considerable investment @ approx $150 of iron per channel. I don't think you could build a channel for less than $500 anyway you slice it, so its still a large investment of sorts.
You can use expensive switches if you want, but the boards should be layed out and the project should be based around the cheapest parts we can find.
Again a good reason not to mount the switches. Leave some degree of flexibility, mount resistors and headers on the PCBs. Wire the swithces up, this allows for front panel spacing. Important if you want to mount these in things other than a 1U rack. For example a 6U vertical rack cassette for a small mixer.....
I think we should really decide wether or not this is the direction the group would prefer to take this project in.
I'm with you - this is the direction this should go in. Simplify the input section, use standard switches for the EQ section. Lets simplfy or get rid of the cut filters, I could do with just a low-cut (HPF), two positions.....lets do it to use Lorlins but not PCB mount them. Leave PSUs and regulators off board, mount the filter caps and discrete amps on the mainboard without the need for plugin modules.....they may prove problematic concerning vertical space and its one more PCB to get manufactured and pay for.
We can still use the original amp layout pattern for the mainboards......
I can still see not a single good reason to use satellite plugin amps (other than it looks cool which nobody concerned with the sound coming out of the speaker gives a F about), this just makes the project more complicated for newbies.
The one reason I can see would be testing new gain blocks for other channels in one complete channel. Ideal if your building a 8ch mixer with these for example......although less of a problem if your just doing a couple of channels in a standard rack.
Also, I can't see how it makes it harder for newbies (like myself). Smaller board to concentrate on, easier to handle and less chance of soldering components into the wrong place. It wouldn't require expensive sockets and pins like the 990 opamps. The pins Brian found are cheap, available and should not add to the complexity.
Plugin modules would however add to the cost due to the PCB fabrication and are a potential issue for mounting problems and vertical space etc....
So I guess I agree - no plugin modules but keep a layout similar to the original at least.
We should spend some time going through the schematic and looking for points where it can be simplified, what the original requirements for the switches were etc.
Then we can put together a specification for the revised version. By that time hopefully we are further forward with the one 'real' problem - the inductor.
The small value inductor could probably be a TOKO or Wilco or something......47mH.
So far, we know we have the input transformer sorted, the active stages can be made, its just a case of format / layout, finding good supply of the semis. The switches need simplifying, the inductors are a real issue. I like Brians suggestions for the input switching....we know we can find suitable output iron.
Cheers Tom
