Slenderchap
https://www.youtube.com/watch?v=y4kYXYMtX44
echoplex said:is this kit/project still available? PCBs somewhere?
jensenmann said:Congrats, Markus! So how does it sound?
.Majestic12 said:Sure, you can buy a kit at the Audio Maintenance Limited online store.
petermontg said:.
Hi majestic
Where do you pick up your Mu shielding.
Best
Peter
You touched on one of my questions. Can you comment further on how it compares/contrasts to a Pultec? Wondering which of these projects to build and given the supply chain issues I'm inclined to go with a pre-prepare kit.It is superb on kick and bass. Much tighter than a Pultec and it allows you to distort the frequency bands you are going to boost.
I'm a little in the dark on tubes. Can you recommend the ones you like for this build?I´ve built this unit in one very pleasant evening and have to say, this is by far the best kit I have ever seen. Also, it was one of the best and most satisfying evenings I´ve ever had cause it culminated in adding a very nice unit to my studio.
Everything is hasslefree, superbly organized and very thought through designed.
It holds ups to the highest standards.
Also, it sounds incredible. I spent a lot on nice tubes. Might be experimenting with different Input and Output Irons though, there is plenty of space left in the case, even though it will mess up the neat inner parts.
Hello Beeswax,I'm a little in the dark on tubes. Can you recommend the ones you like for this build?
Thanks for the details. I'll build it eventually.Hello Beeswax,
hopefully, this is still relevant at least to future readers...
I used the cheapest tubes I could source for V1, V2, V5. I spent about 5$ each and turned out to be NOS assorted GE, RCA, military types. that's cool I guess according to the "hifi scholars"? I guess not a huge demand for those types.
V3 and V4 (the 6SN7s) I spent a bit more. I used Tung-Sol Russian reissues (about 40$ each). My thought was... NOS "nice" tubes can still be found down the line if I hear something terrible! I haven't heard anything terrible! This circuit will probably sound awesome with almost any type of new or old NOS tube in it. My non-electrical engineer brain thought the 4 6SN7s (total for my stereo pair, I have 2 627s now...) should be similar to each other, as they are probably most characterizing the audio. if I wanted 4 of the same """" hifi scholarly recommended nice"""" NOS Sylvania, RCA, KEN-RAD... oof that's nearly the cost of the kit!
For the magic eye, I recommend checking ebay for a NOS Toyo 6E5, they're nice and bright! Buy it from the guy in NY!
I am here to make rock n roll! No more time for a tube tangent!
Not much in there. Do you know where the smoke came from? I’m not familiar with the unit but have you visually double checked the orientation of the components ? Be careful because of the high voltage inside the device (even unplugged for several minutes there could remain lethal voltage) better unload the caps.Hi, I completed a pair of ez627 recently and I'm currently at the assembly step. I decided to try and fire it up on one of my units to make sure everything is alright, but without having the pots/attenuators plugged in, which resulted in magic smoke...
I was wondering if the cause could have surely been the lack of plugged pots/attenuators, or if it could have been something else?
