jplebre said:Crap got the wrong meters, didn't I? http://www.hairballaudio.com/shop/product_info.php?cPath=25&products_id=59
That's what I get for rushing
jplebre said:Hey guys
So completed mine. Time to polish the little things now
Anyone else followed the suggestion to change the cap? (0.33uF)?
I managed to pull the sound I wanted from some snares exactly like the 160's I remember, but for the life of me the kicks just loose all body and get clicky, as if it wasn't fast enough (but this beast is that fast).
Eg. I can match the example in the sound cloud to 99.99%
I did do a silly mistake and installed the BC550 on the RMS section the wrong way around. I'm assuming the "timing cap" is the 22uF tantlum, maybe I damaged the cap?
Ideas before I start hacking at the board?
J
nuclues said:I've measured in DCv mode.Still it doesn't give meaning to my brain why I should measure with the black lead at the ground point,because the pcb it's not connected to the chassis yet so there's no ground connection to the outside of the unit.
jplebre said:freaking great sounding unit.
Anyway, some more things I'd like to report with forumites, to see if anyone experienced this:
- Ratio was working fine today (i know analogue gear can be temperamental, but damn!)
- @Abe, what's that via next to the O/p and the pcb standoff hole? seems that if I put a nut there the o/p stage goes into cutoff.
- with the hairball vu I can't get the meter to go to 0 even with 10k resistor. The TL opamp gets incredibly hot as well after a few turns of the trimmer.
Any other ideas before I get some 1mA meters my way?
jplebre said:eparg, this with normal vu meters, not amperometers?
thanks
tfp said:Hi Abe,
Finally finished my CLX today with VCA200 and it is sounding great, just three questions to be sure:
Calibration of R34 didn't do anything noticable for the distortion, I used a couple of programs for testing, but the differences when turning a lot of times where not visable for me?
For the rev 2 build is it for the Hairball 1ma meter: 1k or 3k3?
What is the average noisefloor what you guys are measuring, I am getting about -76dB with gain at 0.
Thanx for the build, really great and looking forward to use it in the studio!!
RJ
