abechap024 said:tfp said:Two more questions for Abe:
Is THD of 0.38% in the right ballpark;
Is it a big problem if you are a little bit of the -0.011VDC, -0.004VDC?
Thanx!
No, don't get too hung up on these little tweaky calibrations guys, I've gotten the meters and readings and everything to track beautifully, it takes a little time and patience when setting up the meter but very possible. But really, who needs to know when they are slamming 30db compression if they are +/- a db or two?
Put your soldering irons down and go make some music ;D ;D
my problem is that I read perfectly input and output
in GR mode:
meter says 4-5db but the reality is 25db ...
I have a problem in the calibration process:
I can not calibrate 4:1 ratio ...
I do not understand.
thanks
