My left monitor (a Dynaudio DBM50) is making odd computeresque noises, and it happens to be about one foot/25cm above my (home-built clone) PC. I have tried moving the AC and signal wires as far as possible away from the data wires, with no improvement. The previous monitor (an M-Audio) had the same problem, and I've tried swapping L/R connections and monitors with no change, so I am pretty sure it is direct radiation from the PC. The case is mild steel, very new, modestly ventilated, and has a low impedance to ground.
The most obvious solution is to move the PC, but that would be extremely inconvenient (connections for monitors, many USB connections, access to the optical drives in the box, etc.) Plus, I want to continue to keep it as far away as possible from my mixer, outboard, etc. I'm aware that 'real' studios have computers in adjacent rooms, but that's not always practical in your home office.
Is there any in-situ solution possible (short of mounting a well-grounded 50kg mu-metal plate under my desk)?
--mark
--mark
