[silent:arts]
fixed the link:MartyMart said:I can't find your voltage readings in the thread Volker, I think your page is still down ?
http://www.groupdiy.com/index.php?topic=26585.msg330048#msg330048
250V AC means approx 353V DC... 300VAC means approx 424V DC... This is a lot of lowering voltage for the 783... Maybe you'd better put a serial resistor to lower the AC... I'm sure your 783 will feel better with less voltage than with a bigger heater...MartyMart said:Thanks Volker, so my "0" is good and all the rest I have about 3 to 4 volts below
your readings, so that all looks fine.
Perhaps R1 just needs to be bigger in my case ... 5W !
And probably need to move the 783 to the case bottom or side to cool it a bit !!
What do you think ? .... is 300v AC from the pwr traffo a bit much ?
MM.
Yes... on the HT AC line. I don't know the consumption of the DAOC tubes, so I can't tell you the value... I bet it will be more than 22 ohms to notice a real change in the HT voltage...MartyMart said:Do I just need one on one of the AC lines just before entering the board, if so what
would you suggest ?
I have a few 25W rated @ 22 ohms and some 10W @ 10 ohms
The 25W is metal cased with bolt holes and about 5 cm long
MM
Nope my DOAC is also a little dark sounding. I haven't had time to really investigate tho.Am I the only one who is seeing this?
MartyMart said:Mine seems to be unchanged in / out but I'm not measuring, just checking some bright
vocal takes
It sounds absolutely gorgeous, even NOT compressing, stuff just sounds better going through
this thing !!
My Sifams seems to be off though, display almost nothing and then peg left when I can just here
compression coming on .... too sensitive, but come on too late and too fast.
Gold said:Maybe because the vocals are too bright
I replaced R126 with a trimmer and followed the link for instructions on calibrating the LA2A meter. I was able to get the meter dead accurate with good looking ballistics from 1-3dB which is what I'm concerned about. After that it's not that accurate. You could spread out the error over a wider range if you want.
MartyMart said:Na - I just mean that they are as bright on the way out as on the way in ... not "uber bright" !
mikeyB said:Got the same response on 2 builds - they just don't seem happy with either the 10k/10k or the 600/10k Edcor input transformers! Not had time of late for any DIY (getting the sh-sh-shakes!!!) but i did briefly swap input's for sowter 10k/10k - still missing some top, some other sowter 1:3 step up and oep 1:1 600ohm and 1:2 600:2k4 - noticable top and bottom roll-off. The input circuit seems really picky as to what you put in it! In the end, omitted the input transformers and fed it unbalanced!!
The output is no trouble at all. Try it without in tranny - very open sound!!
Would eventually like input tranny, maybe option for both - any thoughts from the gurus?? - are we doing something wrong with the wiring etc, etc????
Gold said:There are a distinct lack of capacitors in the circuit. I'm going to try to measure at different points in the circuit and see if I can figure out where it is happening. I not much of a schematic reader but C102 and C105 seem worthy of investigation.
