mischa said:also, can someone tell me what the H+ is supposed to do? the one located between the two ground pins left of the psu sections.
[edit]
so the unit is finished, but the left channel distorts in the bass, when in compression mode.
otherwise the unit works fine, except for some excess hum on the right.
sounds great, and thanks again for the project!
also a nice christmas present for myself Smiley
[edit]
I switched the tubes, but that didn't help to remove distortion. could it be the vactrols? all other values are the same in the two channels.
mischa said:Little help please...
So i soldered out vactrols (kubi version - 2 on each channel), and now only the right channel compresses. the left one does not with one vactrol, only with two.
how can that be?!
the remaining vactrol on the left side is faulty ?? when you wrote that you switched the vactrols again and again its not clear if you were soldering in and out the same vactrols in the same spots or not.
if one of the two vactrols is good on the left side i believe the unit will compress. just not in full wave mode (ala Kubi mod)
"compression is more equal with only one vactrol on the right and two on the left, than with two on each side."
if im right this would be expected as both sides are compressing only 1/2 of the audio signal.
if you've thought of this and tested to isolate which vactrol is bad on the left side.my apologies. i was uncertain what you meant by switched the vactrols out. good luck. you'll like this unit when it is running with no bugs
mischa said:MM, yes, i had them like kubi wanted, one facing up and one down. Also, Musikding delivered two pairs with different numbers: one pair has 511 written on it and the other one 636. must be the batch number.
...I think that it has something to do with the batch numbers...
