Hi
I'll be building DAOC and was thinking of switchable vactrols, (Also I'll go for a full wave rect. as in Kubi advanced version rather than having leds in parallel & anti parallel). Idea is to have VTL5C4/2 and VTL5C3/2 which is much faster, switchable from the front panel. Now I'm not sure is it ok to keep resistor side in parallel of all vactrols (4vactrols in total in parallel) at all times hard wired, and to switch only the led part(s), or shall i switch between vactrol "sets", both, the resistor and the led part. Hope this sounds clear.
Thank you
Thank you
