Thank you API,
do you have any readable schematics for the 1053, 1055 and 1057?
API said:Lets hope TK audio sees this threa, he did the redrawings of the originals.
I know he have them in higher resolution.
Whats the obsession with the germanium Neve´s Whoops?
Do you want to build some?
API said:Understood, they are indeed very cool sounding machines.
But if you have one schematic you should be set, they are very similar and mostly use different cap values for different frequencies.
Only the 1053 should differ, but no by much.
leadbreath said:Hi gents,
Sorry for delay, I have attached the original drawings from the thread, I haven't included the redrawn ones as they're practically useless.
I have actually finished a set of Input/Output cards plus both the Germanium/silicon inverting amps, just need the EQ circuit finalized. Hopefully this will spur me on and finish this beast...
Mick
leadbreath said:I was looking at building the 1055 as I've got the schematic and its quite simple really.
You can also use all Germanium cards on the 1055 just swap out the B105's and replace with B101'S ( That's why I'm building them all on the small boards to swap them around and hear)
I just need to figure out a way to implement the presence circuit in a more versatile way.
