DIY DUAL GERMANIUM MIC PRE-EQ BASED ON NEVE EARLY DESIGNS
thanks a lot!
quote author=leadbreath link=topic=18356.msg790340#msg790340 date=1460075356]
hi
Ive got the originals from this thread, just bare with me and I'll upload them asap...
[/quote]
I'm gathering information for this project.
As for the Germanium transistors used for each card:
- B100: OC44 (PNP Gemanium), NKT 216 (PNP Gemanium)
- B104: BC109c (Silicon), NKT216 (PNP Gemanium)
- B105: BC107a (Silicon), BC109c (Silicon)
- B101: NKT216 x2 (PNP Gemanium), ACY21 (PNP Gemanium)
- Outside cards: OC36 (PNP Gemanium), NKT216 (PNP Gemanium), BC107c (Silicon) ( The last 2 only if eq is added ).
These transistors can be found in some online suppliers or ebay,
on this stores:
http://smallbear-electronics.mybigcommerce.com/germanium-transistors/
https://www.banzaimusic.com/Germanium-Transistors/
as for equivalent PNP germanium transistors here is a list:
OC44 - http://www.radiomuseum.org/tubes/tube_oc44.html
replacements:
NTE126A , cv7003 are mil-spec made to higher tolerances , AC128 ,  NKT275, 2N527, 2N508, 2N404, 2SB75,  2SA49, OC440, AF239S
NKT 216
http://www.radiomuseum.org/tubes/tube_nkt216.html
Replacements:
AC107 , AC128
ACY21
http://www.radiomuseum.org/tubes/tube_acy21.html
Replacements:
ACY17, 2N1188
OC36
Replacements:
OC22, AL102, AD149
API said:
1057 schematic
Hello API, thanks for the docs.
I also had the 1057 schematic unfortunately the resolution is so low that is unreadable, I have also a 1055 schematic that suffers from the same problem. There's a Wonderlandaudio post at page 7 of this thread were he posted those schematics probably at the time he didnt realized the resolution was really low at least for the 1055 and 1057 schematics.
The schemes for the B100, B101 and B105 at that post although also low resolution are readable.
It would be great to get readable schematics for the 1053, 1055 and 1057 modules.
I don't know which documents were at the link in the first post. is there any chance you still have the Binder1.pdf file? (http://groupdiy.silentarts.net/Wonderlandaudio/Binder1.pdf)
EDITED - 1053 uses a B104 as the output card
updated some more info on the 1060 and 1061
The info I was able to get at the moment is that the Neve modules with Germanium transistors were the 1053, 1055, 1057, 1058, 1060 and 1061.
Those modules used a variety of cards, normally for the mic pre would be the B100 (germanium transistors) card.
Then for the EQ part and output part cards could be either Germanium or Silicon like the case of the B105.
As far as I know these were the cards each module used:
1053
1x B100 , 1x B101, 2x B101A, 1x B104
1055
1x B100, 2x B105
1057
1x B100, 3x B105, 1x B102
1058
1x B100, 2x B105, 1x B104
1060
B100, B105 plus others - incomplete info
1061
Would be nice if someone is able to fill the blanks
There are more, i think each number from 1053 to 1061 was used, then there are also eq only modules like the 2057 etc.
Those are the basics, but i have seen other ones in them as well sometimes.
1053
1x B100 , 1x B101, 1x B101A, probably some more cards, anyone knows?
I used to own a pair but have no pics of the cards, they could be earlier since i believe this was the first blackfaced germanium module.
Whoops said:
1055
1x B100, 2x B105
It had a B104 output card as well.
Whoops said:
1057
Thats wrong, no B102 but a B104 on the output (at least in my module).
Whoops said:
1058
1x B100, 2x B105, 1x B104???
Correct
Whoops said:
1060
I have no info at all on this one
Same as the others.
Whoops said:
1061
1x B100, 2x B105, 1x B106???
Again a B104 on the output.
Basically all the germanium Neves use the same cards, the earliest are the exception.
A B100 micpre, two or three B105 depending on how extensive the eq is and a B104 output card.
