I had to recently drive a new domestic ground spike , the old one is still there ,connected and functional but the termination at the top was below ground which doesnt conform to the regs .
The top of the rod needs to be above ground , a metal clamp is used to terminate the wire , that is in turn housed in a plastic IP 67 sealed enclosure and the connection is wrapped in Denso or self amalgamaing water proof tape to help prevent moisture ingress . 10mm squared cable is the minimum requirement , I went with 16mm sq because I could .
Ive brought the cable up to the utility box , but of course thats as far as I can take the job , I have to wait now for the Electricity supply co to come ,remove the old ground and terminate the new cable into the junction box .
Of course Im well aware what Ive said above may or may not comply or be applicable with the local requirement where you are , main reason Im raising the subject here is the quality of ground connection plays an important role in supressing noise in audio equipment , but might also effect how fast the ELCB trips in the case of a fault current . The spec for the ground rod itself here is 16mm diameter galvanised steel ,1.2m lenght and it must be fully driven into the soil , shortning the lenght isnt allowed .
Anyway if your running audio gear and are experiencing noise issues it may well be worth having the earth rod/termination checked for integrity .
I presume when the Electric co call out they have a way of measuring the resistivity(?) through ground back to the local pole/transformer grounding plate .
