I haven't read this thread so apologies if this was already mentioned but there is only supposed to be one earth ground in a building. If you put a separate earth ground at the other end of the building for example, if there was a lightening strike nearby (inevitable), because the resistance of typical soil is higher than metal conductors, it very likely would travel up into one, through your stuff, down into the other and vaporize everything in between.
That is an interesting hypothetical... Lightning is funny (not haha funny).
Up until recently most residences had a ground spike for the mains power junction box, and a metal pipe water main coming into the house. These days most such new construction plumbing is non-conductive PVC. I have never heard of lightning coming in through the plumbing and out the mains panel ground spike, but that doesn't mean it never happened. My telephone wire drop and even the satellite dish have their safety grounds bonded to the mains panel ground spike.
I am aware of two lightning strikes to my property, one killed a tall tree in my far back yard maybe ten years ago, that tree didn't fall by itself and I had to drop it. More recently lightning struck a tall pine tree maybe 50 yards from my house. My sump pump controller failed coincident with that lightning strike, but the replacement controller also failed without any lightning assist.
Speaking about lightning behaving funny, that downstroke in the pine tree, jumped over to a nearby utility line about 20' from the ground, presumably a lower impedance path to earth than continuing inside the tree. Curiously that pine tree does not appear dead, while the lightning caused obvious damage higher up the tree trunk.
Regarding earth's resistance or conductivity I can share an impromptu experiment. I was trying to use an old sump pump to pump water out of a pool of water created by my leaking water main pipe. I had to borrow an extension cord from a neighbor to reach all the way to the mudhole. I discovered after trying to use it, that "killer" extension cord I borrowed, had line (hot) swapped with the safety ground, so not only didn't the pump work, but the pump chassis was energized.
I wasn't stupid enough to literally stand in the water while messing with mains power, but from standing next to the mud hole I felt a tingle in my feet from the energized pump. It wasn't enough current to trip a fuse/breaker, but enough for me to perceive, so my yard was not very low resistance.
