you mean my old hot water heater that tried to electrocute me? (the heating element rusted through and energized the hot water.) Now my water heater tank is grounded to my fuse panel.I remember a thread called ,my
Hot water heater by John that had some good stuff
Read my sig...Earth/ground is only a valid concept ... for human safety,
Keith Armstrong, an EMC expert in the UK writes:
There is No Such Thing as “Earth” or “Ground” for SI, PI and EMC
Don't you meanwouldn't that be a ground loop?
I believe a notable difference is that in most of Europe differential breakers are mandatorily installed at the distro board and it results in the obligation of distributing both Live and Neutral. In many older installations, Live was run independantly of Neutral, which resulted in breakers tripping if Live and Neutral were not coming from the same breaker.There are small differences across the EU but all 'modern' installations should have 30 milliamp 'differential' breakers (various names used). Thus the live conductor must be 'balanced' by the returning 'Neutral conductor current. This neatly brings me to the fact that all wiring is CURRENT (impedance) balanced thus meaning you don't need power balancing transformers for 'balanced power'. If the live current is different to the Neutral current your breakers will have already shut the power off.
What is the path of the current loop, and what voltage difference is driving current in that loop? I was hoping that JR would put some kind of sarcasm indicator in his response just to avoid confusion.I guess the two ground connections does result in a short ground loop
so most of the fault current will take the path of least resistance
Mmmm...thanks for reminding me that I need to get our place brought up to spec Invoice in the postI believe a notable difference is that in most of Europe differential breakers are mandatorily installed at the distro board and it results in the obligation of distributing both Live and Neutral. In many older installations, Live was run independantly of Neutral, which resulted in breakers tripping if Live and Neutral were not coming from the same breaker.
Installing the breakers at the outlets solves this issue but it's not necessarily good.
There are pros and cons to the two approaches... EU RCDs are typically installed at the panel protecting an entire branch circuit, and the US GFCI protects single outlets, while capable of supporting multiple outlets in series protected by the first GFCI outlet..I believe a notable difference is that in most of Europe differential breakers are mandatorily installed at the distro board and it results in the obligation of distributing both Live and Neutral. In many older installations, Live was run independantly of Neutral, which resulted in breakers tripping if Live and Neutral were not coming from the same breaker.
