Thanks wave.
I typically design my drill layout in FrontDesign, I then export the file from FrontDesign to an .SVG format. Illustrator is capable of handling this file format so it's great for adding in all the text that you want to be displayed on the front panel. I have to zoom into 150% to view the file in it's proper dimensions. I then save it as a separate .AI file, remove all the drill hole circles, reference 'crosses' and import the .ai file into Corel Draw (I have to run this through Parallels Desktop because I'm on Mac which makes the process slightly annoying). I then follow the HPGL conversion procedure as per the Instruction Guide from Front Panel Express.
Also, Ian, as requested, here is a 'rough copy' of the Pultec. I would say most/all of the drill holes and switches have been moved slightly to accommodate the new layout. I don't believe this is a problem as I am sure that all those pots/toggles are mounted off PCB and wired directly? Anyhow, no big thing to revert it to the original layout, this one was a little harder to design than the Helios in that - there is slightly more text and it's a bit harder to keep things legible but 'elegantly symmetrical'.
The knobs/dials used are 12mm, 18mm. I wouldn't recommend going over 14mm for the boost/cut sections as you risk obscuring parts of the panel. If you have the right money I think these could be nice (silver/black).
When I was designing the panel I kinda imagined it to come out with a Neve bluish/red theme, but we all know those knobs cost an absolute fortune and I don't think they come in smaller sizes.
- http://www.banzaimusic.com/Harmony-Knob-Black.html
- http://www.banzaimusic.com/Mini-Fluted-ABS-knob-black.html
- http://www.banzaimusic.com/Aluminum-knob-black-notched-tip-19mm.html
Don't mind me just taking up all the space in the thread :-X
Without knobs/dials so you can see if everything fits.
I may start drawing up the HPGL files soon when I get the time, my mic bodies just arrived ;-)
Take care,
Braeden
Edit: My dividers got messed up for some reason, they should be centred and not biased in length to the right.
