Hey Ian,
that was too easy
I'am a little bit confused right now, after jumping back a few post on this thread. In a past post i asked about the trimming of the 2nd gain stage. Because the EQ works by changing the gain of of the 2nd amp by altering the negative feedback, in my scribble the gain trimmer is still there? Your answered at my question:
So my question is: Is it really only lifting the 100uF/250V from ground with the actual amp card, add the whole EQ parts as shown in my scribble and i'am good to go? The gain trimmer for the 2nd amp stage is still there?
Thanks, Sven
that was too easy
In the diagram the signal first goes to the channel fader via a 4K7 trimmer pot. It is this trimmer that is used to trim the overall gain. It usually drops the input level by about 2dB. Then the fader has 10dB in hand so at its 0dB position it attenuates a further 10dB making a total loss of 12dB. The amplifier then adds 18dB of gain so its output level is +6dBu.. The VTB2291 then drops the level by 6dB because it is a 2:1 transformer and the output ends up at 0dBu .
Thanks, Sven
