> contributions on attack and release times
You don't need specific numbers. It's DIY, you give a table of R C values builders can select to taste.
You do need the extremes. Fairchild's goal was ANY audio bandwidth event, 0.05mS (50uS) so that a cutting-lathe would NOT over-cut. On one hand we now have faster channels, 48KHz and 96KHz. OTOH an "over" in good digital gear is a non-event. Good arguments have been made that <5mS clipping goes un-noticed. Some engineers disagree so 1mS could be a goal.
At the other extreme, >100mS release ratchets-down the average audio level, opposite of what we think a limiter should do. If every P-pop drops level and it takes a long time to recover, a P-popper results in a weak sea-sick level (much like my over-processed cable-TV operator). OTOH sometimes the goal is clean and natural not pumped-up.
Short-release piano is awful (even in pop music; why the Rhodes was much-loved).
Piano initial transient is sudden, so attack must be short.
We can change the magnitude of _both_ attack and release by changing the capacitor.
But the _ratio_ of attack to release determines the ratio of cap-charge current to cap-discharge current. This sets requirements for cap driver and cap load.
With simple tube limiters, attack current may be <10mA. Discharge is limited by ~~0.1uA grid-current, but this is very variable so the user-control discharge must be much higher. Taking 1mA and 1uA we can have 1,000:1 ratio of attack to release. 1mS/1Sec, 5mS/5Sec, 0.05mS/50mS, etc.... but such diverse choices require cap-change. To handle 0.05mS:10Sec plus variable leakage we need 2,000,000:1 ratio of charge to discharge current.
With the six grids in a Fairchild we need a really hefty 2x6V6 sidechain driver.
For the much narrower time choices in a Federal we can get away with a single triode.
(Yes, arguably such wide ratios could be done with dual-constant networks, or even Audimax/Volumax dual-boxes, but too late tonight to get into that.)
BJTs do big current, JFETs do small current, better/cheaper than any affordable tube sidechain. This does multiply the problem of fancy limiters needing multiple supply nodes at various polarities at wide range of voltage.
So what is the sweet-spot of practical charge/discharge currents? Obviously each designer has to work this out so the users will be pleased.
