Doug,
Nobody else has commented on the size of the beast so you might get your choice!
Following PRR's suggestion, I have attached a proposed table of attack and release values, obviously guys can modify them to suit their personal taste.
I have found that for punchy bass it helps to have the release just after the attack time so that is why I've got some of the values there. Six positions is a handy Lorlin switch and the R values work out nicely. Just in case some can't follow, the resistors are in series across the switch positions so they all add, this technique helps to cut down switching noise.
Its difficult to get 0.25uF caps in the UK so I intend to use 220nF with a 33nF in parallel.
More input required on the shape/rack size required, it will be going to metal very soon.
best
Davep
