Sorry my bad now that i read i see u testing with dmm but also mentioned +meter but thats meter from the gssl.jjaskuna said:"Ill be back and able to test in about 5days but what do you mean? Ground being *star ground on gssl chasis connected to common terminal on dmm. Possitive pole being poss dmm connected to? Not sure what u say here
Maybe its me tho hehehe"
My grounding scheme is: Ground from audio input of pcb connected to right XLR input ground, Jumpered to Left XLR input ground, jumpered to a screw that is drilled into the chassis. Also connected to this screw is a wire that attaches to the ground of my ICE power connector. Not sure what a star ground is thought....
By "positive pole of my meter", I mean: the connector on my meter that the red wire attaches to. The red wire then attaches to Meter+ or M+ (can remember which it is on my PCB) on the control PCB.
Jeff
My gssl i had to make ground connection directly to that screw drilled to chasis (star...) to make continuity.. I think on the schematic there is ground there.
