Harpo said:
Missing jumper at sidechain insert.
Ah, thanks for spotting that. I completely overlooked it. I just put it in now.
Harpo said:
Main problem seems your secondaries transformerwires pcb connection. Using a magnifying glas might help to spot and remove the short between the center pin and an outer pin of your AC connection on pcb. Soldering these wires from traceside seems adventurous and already might have broken/lifted a pcb trace from soldering heat and mechanical force/weight of wire. Fit wires from component side (and use a Y wiering for the center tap connection) or use a 3-pin terminal (screw)connector with 0.1" or 0.2" pin spacing (that's why there are 5 holes on pcb).
I re-soldered those wires before adding in the sidechain jumper. Made no difference. I resoldered them again
after adding the jumper and now the toroid seems to be working fine. Had it powered up for a few minutes so far and no excessive heat, no burning smell, seems good. 7915 voltage has changed to -22v though. What is the voltage supposed to be? I had it at -15v before.
Anyway, the +15v and -15v rails are working perfectly, so that's good. I passed some audio through it and the meter seems to work fine, threshold works, I think all the controls are working in fact. The led dims when I turn the make up gain to full. Not sure why. Not a big deal though.
7815 and 7812 still read 0v. Is the 7812 only used for the +12v relay? If so, then I guess I don't really need that anyway. As for the 7815, isn't that for the +15v rail? My +15v is working fine, so maybe my 7815 is too, I dunno. Is there a diagram or something that shows the correct voltages?
Harpo said:
Twist each pair of at least input hot/cold wires between XLR/pcb, so the balanced line receiver has a better chance to cancel out induced garbage.
Ok, I'll do that.
Harpo said:
Maybe optical artifact, but pics seem to show some XLR-pins1 shorting to other XLR-pins2/3.
Those aren't actually shorted. Picture just makes it look that way.
Harpo said:
Get the center red wire from the pcb output connector away from below your pcb and insulate its open wire end so it doesn't short things out, if you wouldn't cut it off.
It is already insulated. Just not visible on the picture.
Anyway, thanks for all the suggestions. Seems to be pretty much working now. And thanks to everyone else who took the time to respond.
