I think this thread isn't quite long enough... so i'll add to the general confusion
bought a "non-working" build a month ago. redid the i/o and power connections and bam. worked like a charm.
added the Expat Audio Turbo board... even better... when i say "worked like a charm" - i mean i mixed 11 out of 13 songs of an album with this thing on the 2mix. it sounded just great.
then this problem surfaced:
the unit would "die" after a little while using it. LED would go out, meter would lock halfway through it's throw, etc.
i thought it was heat related, since when i had the top off to troubleshoot, it almost never happened. almost.
i benched it again and replaced the +/- 15v and +/- 12v regulators with new ones, and when testing... it dies within 30 seconds all the time now. (this is again, on the bench, top and bottom lids off). When i say dies, i mean the +12v rail is going down. -12, and +/- 15 are all still good.
i took the turbo board off the +/- 12v and gnd connections, and redid the sidechain connections (i.e. undid the mod) and unit looks good for a while longer... but still goes down. I metered the +12V line and paid attention to the voltage:
with the threshold set all the way CW, i can watch the +12v line slowly, but steadily drop from 11.88v to 11.6ish in anywhere from 5 minutes to 30 seconds, depending on how long the unit has been on...and bam. out it goes (the +12v rail). with the threshold fully CCW, voltage drop still happens, but way slower. removing various chips (VCAs, TL074, etc) i still see voltage drop, but at a slower rate.
fully CW on the threshold pulls down the +12 rail.
any ideas where to look ? anyone see this before?
thanks all!
-pete
