Majestic12
turk sanchez said:...how do you guys keep from having a large bolt sticking out from the bottom of the single space rack enclosure (the bolt that mounts the power transformer)? Are you guys drilling a counter-sunk hole and not using the washer?
Any tips on this would be appreciated.
Usually I drill a countersunk hole in the bottom of the case. If the case material isn't very thick or if the power transformer is quite heavy, I reinforce the metal with a 5mm thick piece of round plastic thats glued on the case with epoxy.
