Today I will do the same, I will pass sine waves and look for the path, thank you for the tip, although, as I wrote, I measured the voltages and measured all the elements where the analog signal goes and there is perfect symmetry, I selected the resistors so that they are identical, the capacitors too, but I will check, thank you for the tip
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a 4 dB drop on the right channel all the time, both during compression and bypass.
update: I passed a 1kHz sine signal through the signal path: at the inputs I have: 28mV and 28.4mV but... I checked how the cables are connected to each other without GSSL and they have a perfect 28mV for both channels. I don't know if .4 mV is a lot...? I went further and at the input of the ne5532 opamp I already have 6.8mV - R channel and 6.2mV - L channel... at the input of the operational amplifiers after the capacitor I already have 1.2mV left channel and 1.8mV right channel. So there is a difference, but I don't know if it is so big that it affects the 4 dB drop? I can't compare it, but there is a difference. But I don't know what causes it, because from the very beginning the left channel is getting bigger and bigger.I followed the entire signal chain and the output of one of the VCAs is 10.8mV and the output of the other is 6.2mV, so this is a significant difference, I only increased the sine input signal a bit... but at the outputs of 22uf capacitors, from which the signal through the res\ The 27K ystor goes into the VCO and is respectively: 1.8mV and the second one is 1.2mV. I replaced the VCA channels, I have the 2181 and it is identical, so the VCOs are functional, I think, there is also this difference at the JRC 5584 outputs, but... at the inputs it is much smaller, i.e. 6.8 mV and at the other 6.3 mV... but it is I also swapped places and it's exactly the same, so I don't know where the signal is lost... I have no idea how to check it to locate the element of the audio track that is responsible for it. I will also add as a side note that when changing the settings of the attack and realise controls, the difference increases slightly to about 6 dB at extreme attack and release settings. But the problem, in my opinion, definitely lies in the signal path.
