Hey there guys,
I just asked Greg for some personal help with some problems I'm having with 2 SSL clones I'm building, since I was afraid of sounding really dumb on the forum. But since, I can really hide it anyways, I thought I should ask here too. Maybe others with similar problems can benefit..
I have 2 units but I'm only going to describe one at the moment.
I have no way to do audio testing at home, so I just decided to start with power and this is what I found:..
7815 23.7V In and 14.7V Out
7915 -23.6V In and -14.9V Out
78L12 23.5V In and 12.2V Out
79L12 -23.5V In and 12.0V Out
I basically comcluded that my power rails are fine with regulators working correctly.
I moved on to checking power at the ICs (with chips in sockets) and this is what I got:
5534 Left input
Pin4 -14.97V
Pin7 14.78V
5534 Right input
Pin4 -14.97V
Pin7 14.77V
5532 Left out
Pin4 -14.97V
Pin8 14.77V
5532 Right out
Pin4 -14.97V
Pin8 14.77V
So I guess it is safe to assume that everything is going fine up to there.
TL072
Pin4 -12.07V
Pin8 12.21V
TL074
Pin4 12.22V
Pin11 -12.07V
I guess everything fine here too..
Time for sidechain VCA
Pin5 -8.62V (?)
Pin7 12.22V
So I figured there is something funky between the output of my 79L12 and the SC VCA but I couldn't find anything... hang on, I'll take another look..
So, by looking at the schem and pcb, I noticed the 3k9 resistor in series with Pin5 of the VCA. That could be what is causing the voltage drop, right? if so, then this reading is correct, right??
I went on to measure the Voltage points that are labeled on the pcb, just to see if everything was OK and poked around and remember something about the Voltage labels on the bottom of the unit not being exactly next to the voltage points. So I measured around on the spots that I thought should be read and they all seem fine.
I guess my questions, after this long description, is the -8.6V on the SC VCA any concern? and is there anything else, power wise, that I should check for??
maybe some DC on the other pins of the chips or anything like that?
WOW.. I just learned so much doing this... this is great.
Thanks a bunch
Gil
