vertiges
Thank you Joachim !!!
eD)))
eD)))
check if R16 (100R) connects to the tip of your rca plug
1) Value should be 10k, else your signal will drop by 6dB. If you have both 20k's already placed on your sidechain board, keep them and feed both inputs/resistors with 1 signal (2x 20k in parallel=10k).bassculture said:hi,
i've built 2 12afael / clintrubber sidechain boards.
i also got a turbo board, wich is not connected for the moment.
so i connected the two boards (ins & outs @ the 47K summings resistors on the gssl pcb), 1 for left, 1 for the right channel.
1/ i'd like to know if there is any change to the 20K resistor at the input and/or 47K resistor at the output on the sidechain card
because those cards were designed to received L+R at the input & not only one channel.
2/ i'd like to know how to set up the trimmer that control the output level (VR10) of the sidechain card.
to increase the gain should the R9+R10 high or low ?
i tried to adjust VR10 while compressor was on & i didn't notice a change.
(but maybe that's normal because the output of the two cards are summed...
3/ my question 2 is because i can mesure a AC at the input, but when i try at the output i get a value that decrease to 0 very fast (less than a second)
i mesure this against audio input or output ground.
Harpo said:preferably sidechain switched to bypass, else with a signal above cutoff frequency (see previous post by DaxLiniere), and adjust the trimmer to match input with output level.
2/3) The 47k at output of the sidechain board is the summing resistor, substituting the 2x 47k at the gssl mainboard. Sidechain Out is the summing node/virtual ground of the following stage, so measure the signal level just before this 47k resistor on the sidechain board with preferably sidechain switched to bypass, else with a signal above cutoff frequency (see previous post by DaxLiniere), and adjust the trimmer to match input with output level.
