One that sounds good in both, at least on average. I can do it all the time with great results.But ending up with only one mix/master? Which one? The one that sounds good on headphones or the one that sound good on speakers?
Can mix on my speakers, then check on my reference headphones, do some small touches, listen back in the main monitors maybe do also some small touches. After that I bounce the mix and to me it sounds pretty good on speakers or headphones. I might also listen to it in my car before I send it to the client.
I can also do the opposite mix primarily on headphones if I work outside the studio and then do some small touches in the end on the main speakers.
I’m as happy with the result as I’m happy when I do it on speakers.
I also have the Auratone to give me another type of reference, butt I will probably change those for a Small common Bluetooth speaker, it makes more sense to me at the present.
People have been mixing for different playback systems forever, you can’t control or imagine all the different ways people listen to music, but you can achieve a mix that sounds good on your prefered main speakers, and just reference in other playback systems to know more about the average it will sound in the real world.
When I finish a mix, Im normally happy how it sounds in consumer playback systems.
IMO issuing only one mix/master for both makes as little sense as using the same master for both AND vinyl.
That I really don’t think it makes any sense.
Vinyl has so many limitations that you need to change the digital master to prepare it so it can be actually cut on your plastic. Otherwise mechanically it can’t be cut, or you end up with something that reproduces an horror story,
Actually there are a lot of Bluetooth speakers that sound good, actually better than most of cheap/crappy consumer hi-fi systems of the 80s/90s.
I find that a good mix/master will sound also good in a good portable Bluetooth speaker.
Of course, but the typical scooped sound with over-inflated bass is dominant. Should we mix for those?
Not my favorite choice or prefered choice for sure, but each person should use what they think
Works for them.
Everyone works differently and have different personal monitoring choices, and a lot of people are getting good results. So what works well for you it’s fine
I would never ever mix on NS10, the lack the last 2 lower octaves and the last upper octave, to me they sound horrendous and don’t offer me any help in mixing.
Saying this I listened to so many great sounding records mixed on NS10, do I completely respect people that choose to monitor on them
If you work differently than me that’s completely fine. But what I wrote is what I find to be useful and my personal advise
