Oh great switcher-hacker:
Got a crazy product idea. It won't sell in Atlanta, but there may be a global market.
I have heard that there are US-market guitar amplifers in Australia, and surely all over the world.
They use step-down transformers to turn 240V into 120V so they don't explode.
But they still have 50Hz, which strains iron wound for US-type 60Hz power, and the transformers overheat after a while.
Cranking the "wall" voltage to 96V gets the flux down, but also under-volts everything in the amp enough to sound lame.
It is "simple" to make arbitrary "wall power". Get a big audio amp, a step-up transformer, and an oscillator of the desired frequency. There are amps made for this work. They are big and heavy and expensive.
You'd think that a motor-generator would work, but it isn't as simple as that. (Aussie motors turn 3,000RPM, while we get/need 3,600RPM for 60Hz machines.)
The 60Hz isn't really critical for an amplifer: 70Hz would be fine too. I have a hack that probably won't work.
So what about rectifying the 240VAC 50Hz to DC, then chopping it very fine (>5KHz) with a PWM, and reassembling the slices in a low-pass filter?
I think even I could do that.
BUT. Noise rejection and safety laws and old baked insulation really require that one side of the "120V 60Hz wall outlet" be common with the local wall-power and nearby dirt. A simple bridge would give an output 160VDC above local earth. A voltage-doubler could give +/-320VDC and a hot leg symmetrical around earth, but that's heroic voltage. Of course a 60Hz transformer would let us float the output down to any earth we like, but that's a big lump.
Any thoughts? Could it be a PC power supply size box for $99, or does it end up looking like a big audio amp and transformer?
