bcarso
The class D amp will be something somewhat special, but not intractable. IR have high side drivers that will handle 600V for instance. They are not as fast and low jitter as their fancy full-bandwidth audio-oriented ones, but we don't need that for 60Hz sines.
Once you get the drive circuit together and select the HV FETs and output filter, the PWM need not be very complex: a triangle wave generator and a comparator, or a free-running feedback oscillator around the whole shooting match with if you like a sync injector. The high/low driver chips will help you steer clear of Fire Emitting replacing Field Effect more or less out of the gate (no pun intended, and why I am on a sporting event kick tonight I can only guess).
