I haven’t actually had the time to test it yet, hopefully I can give it a try this weekend. I reached out to Klark teknik but they couldn’t provide me with a schematic or which capacitors was wich.Did you find if those were it?
Is this what you ended up using for your mods? Mouser CartThe red one at the bottom (22nf) and the two yellow ones above it (100 nf) are directly in the signal path. The two yellow ones next to your thumb are in the sidechain, no point in changing these IMO.
I used what I had around, mostly Solen Fast, but I think in one of them I used a WIMA cap or two.Is this what you ended up using for your mods? Mouser Cart
I did look at it with the scope and found some but not so much out of band SMPS garbage. Still have the linear PSU on the to do list, but without a schematic of the KT2A it's not so much fun with these high voltages...If the KT2A is anything like the the EQPKT , theres a ton of out of band garbage between 50-100khz from the SMPS , I use 192khz sample rate with REW to look at the output ,
I'm doing a linear off board psu for mine ,
Yes, I'm pretty sure that the main HT voltage goes through an RC filter on the PSU PCB and then to the audio PCB. But there are other voltages. I already got zapped once poking around at that board.Ive been able to look a bit closer at the ht regulator circuit used in the EQP,
both 12ax7 and 12au7 HT rails are derived are after it ,
There doesnt seem to be any regulators on the KT-2 main board so most likely there on the PSU pcb ,
you should be able to check the supply voltages at the 5 pin molex in the middle of the board then you can estimate the total currents .
It looks like you kept the big yellow 10uf cap before the output trafo. I thought that was one of the worst offenders.I just finished up the mod using the parts from my Mouser cart. Sounds great! For a few bucks it was worth it to me. Especially after investing in a Kenetek and old RCA's.
This took about 1 hour from start to finish for anyone interested. For someone without ADD it may go quicker! The trickiest part was solder-sucking after removing the original components. Had to be careful not to burn the board and went slow and steady using braided copper along with a sucker.
Here's an inexpensive high voltage PSU and trafo, I wonder if these would be of use to pimp the KT2A. Mosfet filters on the PSU and 40mA output. 280V DC derrived from 265V AC, should be close enough to the nominal 275V DC:Ive been able to look a bit closer at the ht regulator circuit used in the EQP,
Okay, I also remembered the usual 12BH7 being taller. The JJ seems to be more the size of a 12AU7.12BH7-A from JJ is shorter than standard 12BH7.
