mikep
I don't know, this might be useful to someone. I once designed a GR metering circuit to work with an opamp labs model 37 (IIRC) compressor module. this thing is an octal can with only input, output and power pins. there is 30 dB of built-in gain and a fixed threshold. the comp is optical and actually sounds pretty good but it is quite hard to use gently without any metering. the circuit could be modified to work with any compressor as it just measures the difference between input and output level. it worked surprisingly well.
one small drawback is if the level quickly falls to -40 or so the meter will instantly go to zero regardless if the comp is still slowly recovering. looks pretty bad on a LED bargraph but is not even really noticable with a mechanical VU. I had to fudge a bit to get enough range at the expense of accuracy. for very small amounts of GR it is slightly exaggerated (actually a beneift) and it maxes out at about 20 dB, which is about where that opto stops compressing and a VU doesn't have much resolution down there anyway. I can share the schematic, but not right now because I am away from home till next week. But I probably gave enough info to recreate the circuit.
mike
mike
