Hi again guys !
... so, I finally found some time and calibrated both my units.
Went rather smooth. Followed the instructions in the manual, 11 - calibration and 12 - Ratios.
What I can't really grasp is 15 - Stereo Threshold trim. should i put the voltage on the stereo link (point 15) on
each unit and do it like the manual or should I just switch to stereo mode and feed an equal signal to both channels
and check that the compression is equal ? (within reasonable limits)
Should I even bother ?
How did you do it guys ?
