Matthew Jacobs
Insomniaclown said:I know that 2:1 ratio is much different than the others. I haven't done too much experimenting with it yet, but it sure does suck down the gain.
Yeah, same here. When I go from position 2 to 1 on the ratio switch my gain reduction hits hard. I have to back off the threshold quite a bit.
Looking at the compression graph in the manual this is completely normal as the soft knee means the Gain Reduction kicks in, slowly, way below the threshold.
Insomniaclown said:This is my first hardware compressor, so I do need some time to get used to using it. I did some vocal recordings on it yesterday, and I loved how it sounded!
Damm Right!!! not my first hardware compressor, but my first "high caliber" compressor. Used to have "toys" such as the new Joe-Meek, Focucrite voicemaster and other "gizmos". When I first built and heard the LA4A I was blown away.... Especially nice on bass and vocals, whenever you need character.... now I'm selling all my other studio equipment so that I can build more DIY...
Hey bro did you ever sort this out?Insomniaclown said:#2- My threshold control is super sensitive. A 1 mm movement results in massive GR. I have yet to adjust it with a test tone though, so this may be cleared up when I get to that.
I have the same problem, I think it's because my pot is wired the other way round. I think on the original you have to turn the pot cw to lower the threshold. But I like it when you turn the switch ccw to lower the threshold and increase compression.
At the moment with my log pot wired the other way round (ccw for compression) I get, as insomniaclown says, a super sensitive threshold. Does this have something to do with the tracking of a log pot? as in the curve is steep at the ccw position?
If I want to keep the action of this pot the same (ccw for compression) but want smoother control, would a reverse log pot work better or maybe a linear pot will do?
3nity said:Alirght i found those but they are 9mm not 10mm!!
Any thoughts?
Hey, 3nity, I think does trimmers will do fine. Just stretch out the feet a little. That's what I did on mine...
J
