Rybow
In my first channel I had the NSL 6910 + LED configuration. I tried the 20K resistor in parallel with no luck, but increasing the trimmer to 1K gave me a bit more control. Not enough to get the ratio adjusted properly, but it did make a difference.
I did finally get a chance to try out a different LED and the MC33079. I used a small 50 degree 800 mcd led, and I noticed right away that I had more control over my threshold. I could actually dial in moderate amounts of compression where as before, it would slam everything. That was when I had a 10mm 35 degree 2700mcd LED in there. I am not sure if it was the LED's or the MC33079, but the sound is much more transparent which I love. It used to do something odd in the low mids which just added some mud. Distortion is less as well. On the downside, I cooked something with all the components I have been changing out. With the input sensitivity switch in high mode, everything sounds OK, flip it into low, and my head almost got taken off by the white noise. I can turn the noise up with the output control, and it reacts to audio in that it seems to distort the audio. For now, I am pulling this channel out. Will probably order a new PCB and remake it as I have no idea where to begin searching out the issue. It was so quiet before I started messing around in there! Oh well, live and learn.
My second channel should be going in (finally) soon. I am using the NSL 32 in this one, and am pairing it with the cinemag CMOQ 2S OT. I did a way better job on this board, so I am looking forward to hearing how it sounds!
