LA-4 Help Thread!
Luny Tune said:
It seems the red LEDS is not so "standard" after all. Or rather: Many different types fall under the catagory of being "standard". The ones that work for me right now are 2V, 20mA, 150 mcd.
And right now the ones I found here in Denmark was these 10mm ones:
http://el-supply.dk/?Gid=210&VNr=45A.2D
I have bought some of these 5mm ones but haven't been able to test them yet:
http://www.electrokit.se/opto-led-rod-lysdiod-rod-5-mm-standard-diffus_40300051
They're "only" 1.65V but I suspect that the critical point is the 20mA current they need, so I hope they'll work.
Just need the 6910 LDRs I've ordered to test them...
Lunny, ilfungo...
what do you think about trying this one?
http://www.datasheetarchive.com/CLM6000-datasheet.html
http://www.banzaimusic.com/Clairex-CLM-6000.html
hello pedroplanet
I do not know what to say
should be tried ....
with VTL5C4 / 2 are very happy with the sound
I just have to solve the  stereo problem
I'm experiencing, I'll know.....
ciao
No, the threshold trim should be adjusted for normal operation too.
@Pedroplanet
The CLM6000 looks very interesting. The 20mA/2V for the LED in it matches the LEDs that I use and the LDR in it have specs not very far from the NSL6910 as far as I can tell. 6910 goes down to 100Ω where the CLM6000 goes down to appr. 500Ω like the NSL32.
Try it out and report back. :)
hello Luny
I tried everything to run in stereo the compressors
I think my problem is always the ratio calibration ...
I also have another question:
when I try to calibrate threshold (mono) get-1dB with + /-40dB (input) instead of-25dB
might explain the adjustment threshold?
trimmer R57 for stereo and mono threshold adjustment?
I continued to experiment
I replaced  vactrol with silonex NSL32
I do not like the sound is distorted and far less controllable,
I re installed the vactrol and after some experiments I've seen  that 2:1 and 4:1 ratio work in stereo :D
8:1 12:1 20:1 no
ideas?
Thanks....
yes, yes, yes! ;D
Luny Thanks!
work in stereo!
I want to thank you for the wonderful project and your help
Beautiful sound, maybe better than the original!
is possible with modifications to mount a transformer input (OEP)?
Thanks ;)
I replaced one of vactrol and
remade calibration
later will post files for you to hear the sound...
hello
I would make another LA4 transformer output urei 11148 ...(bought on Ebay)
is it possible?
some fit?
if you want to go 500 series format I can give you the fpd files for this:
http://www.groupdiy.com/index.php?topic=32615.msg441075#msg441075
helterbelter said:
Does anybody here have a frontpaneldesigner file for the LA4 who's willing to share it ?
Ciao
is an idea ...
edit it as you think
I reversed meter switches with  ratio switch
if you want the file. FPD send me your e-mail
I can not attach  FPD files
  • DUAL LA4fpd.pdf
    48.6 KB
great guys !  ;D
Well, I´m looking for a 2HE 19" panel, I don't have a 500 series rack, and I decided not to put it in SSL 5K cassettes either. I might do Volker's 51x once, but not soon. Nevertheless, your la4 cassette is looking killer, Briomusic !
Ilfungo, yeah, looking good ! PM'ed you.
