Insomniaclown said:
YTell you the truth, I completely ruined my first PCB when I started this project, so you are already one up on me.
Well, today, replacing the 7918 one of the solder pads went out, so I wired it point to point and attached it to one stand-off under the PCB, not the best way, but I think it´s functional.
Well I replaced it for fisrt time and it gave me 21V
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, so I replaced it again, 21V, exactly the same than the other, the voltage between input and ground is the same in the 2 regulators, aprox 30V.
Ok, then, thinking and thinking I had a posible solution, I put a 1M, 1/2 Watt resistor in series in the -18V rail, and then dropped it to 19.8 V, so I put another one, and then I had 17.8V. Is this too bad?
I built a wire with the two resistors in the - wire, I plugged it into the comp and the power supply, run it, and no smoke, it´s ok, but I noticed a hum coming from the toroid (the input and output aren´t connected to anything), and it get really, really hot, I don´t know if it´s usual, as the noise.
Also I´ve seen that the needle in the meter doesn´t keeps in 0 with no audio passing in GR mode, but it goes to -20 in the other 2 positions.
I couldn´t pass audio, i´ll try it after, but I´m a bit worried about the toroid
