[quote author="NewYorkDave"]All right, I've been thinking about various ways to handle the bussing and mixing. I wanted to post a sketch of this idea before incorporating it into the updated schematic; let me know if you see any flaws that I may have overlooked.
This is for assignability to a main L/R buss and two subgroups. It could be increased to main L/R plus four subs by changing the 22K resistors to 33K.
The reason for the unusual assignment switching is twofold. First, the panpot wiper needs to be loaded with about 10K to give the correct "law." Second, for my own perverse reasons, I don't want the noise gain of the mix amp to change as channels are assigned to/removed from the buss.
I used a variation of the differential mixing setup shown in Fred's PDF, with a little tweak to minimize input offset voltage--which may not be anything to worry about, anyway, since the amp output is capacitively-coupled.[/quote]
Except for my personal objection to using "buss" for "bus", it looks straightforward.
I don't know if you have RF concerns in NYC :roll: but one trick you can play with 100 ohm in series with - input is to actually incorporate a 2 pole active LPF with C to ground at actual bus and feedback resistor now connected to bus side of 100 ohm resistor and C from opamp output to minus input. C to ground perhaps useful for antenna length bus runs. Not practical for audio bandpassing but high noise gain buses can actually rectify in high RF environments when using bipolar input opamps. I recall once correcting a RF problem in a small mixer by swapping in a BIFET opamp on the mix bus. Noise wasn't a problem in that case since it was only a 6 input mixer.
Running constant noise gain isn't perverse but not common in commercial products because customers don't understand residual noise floor with nothing assigned, despite it being inconsequential in real world use.
Side benefit of constant noise gain design is possible use of decompensated opamps or seriously decompensated discrete approaches. Note: you can't take advantage of decompensation if building in active LPF as that requires unity gain stability.
Does value of 1K on + input (bus side of cap) need to be raised to = 1k in parallel with 22k for proper forward ground reference ?
