The Tele stuff is three chambers.
I haven't checked capacitance. UTC also made some plate chokes, but pretty rare on evilbay.
from ollie's site:
"The three-chamber plate inductor is mainly responsible for the high dynamic range of the V72 and V76, also the one that gave us a big head ache. Instead of a plain old resistor, a high nickel content inductor is used for inter- and output stage. About 6000 feet of magnet wire that is roughly 1/4 of the size of a human hair, wound with approx. 30000 turns onto a three chamber bobbin, keeping stray capacitance as low as possible. We found a bobbin manufacture that still had some NOS stock, but after getting the first samples, 40 years on a back shelf in a wear house made them same as fragile than the ones you find in the historic V units. Just careful touching can result in cracks or breaking. New ones couldn't be made, because tooling was decommissioned in the later 1970s. After several tries to replace it with Ferrite inductors, etc. we made a new set of tools.
So what is so special of this design? Not very often used in audio circuits, the only other application that we could find out was audio equipment made for the US Navy in the 1940s. The inductor allows a very high amplification over a wide frequency range with hardly any random noise created by standard plate resistor. Effective AC plate resistance is nearly 1M Ohm with a fraction of DC resistance, aside higher dynamic range, better S/N noise, it also allows less intermodulation distortion that gives the V72 and V76 its classic wide open tonal response."
http://www.tab-funkenwerk.com/blueprints.html
cj's custom diy chokes-M6 for less bass distortion but lower inductance:
