benlindell said:
I wired and fired up my first channel.
Lots of noise and the occasional AM radio. I tired jumping the input tx with 2-3 and (1-2, 3-4). Tried 2 different opamps. At the most gain I get a little bit of highpassed signal from my mic.
I grounded the IEC earth to the star point on my PSU and then to output and input pin 1. The only thing not hooked up is +48V supply.
Any ideas?
i still consider myself pretty green so maybesome one can confirm my suspicions (or explain why they're not valid)
if you are picking up AM wouldntthis point to a sheilding (lack thereof) problem.
my build is notcomplete so i cant speak from that perspective,but i used sheilded wire to connect the main board to ouput pad/phase board and will use it from mainboard to my stepped attenuators when i complete them.
