mikefatom
The Aux output is simply the third secondary winding of the output transformer.
You can use it as another balanced output. However, it will have 6dB less than the 'main' output.
You can also use it to feed a VU meter.
In any case, you should always buffer the signal going to your VU meter circuit.
