MK-U47 - build thread
ioaudio said:
One more quick rendering from my drawing, also showing the innards:
Hi ioaudio
do you have an AutoCAD drawing for this mic?
Opacheco.
I need the 3 screws for the head basket and the one screw that mounts the body to the bottom bell on the mku47.  Got lost somewhere in the shuffle/  anyone know what type of head and what size these  screws are? Max you out there?
Hey Max,
I make a manual/build book for each project i build, and i was wondering if you could email me a BOM with the manufacturer/part number of the components you sent in your kits.  I purchased two kits from the original batch and i'm just now getting around to building them.  (Long story)  If it's not possible, i completely understand.  I've already pulled the values from the schematic, i'm just looking for the details on the specific components you chose for the build.  If anyone needs to repair the mics in the future, i want them to have the correct info to purchase the right replacement parts.
Thanks again for the nice kit!  I'm really looking forward to finally building these.
Citrus Hill
[email protected]
Hey guys,
Is it normal that the mic's PSU drops in voltage after around half an hour?
Lately we've heard some distortion out of the mic and we've noticed that when we bias the voltage to 105 it drops to 102-103. So now we've biased it to 107, and after 30 minutes it drops down to 105ish.
Are you biasing the mic after it's warmed up? Warm it up for an hour or two and set for 105 see if it drifts. 2V isn't much, I doubt it's causing your distortion. Can you describe the distortion? Is it always there or on transients?
Was it you that had trouble with a muffled sounding Beesneez capsule? Did you get that resolved?
I'm selling a complete MKU47, if anyone should have interest !
https://groupdiy.com/index.php?topic=65455.0
already sold
I'm on vacation for March Break and thought I'd spend some free time finally getting this MK-U47 up and running.  Of course, now I see all the build pictures are missing!  :eek:
I don't suppose anyone made a file with Max's build post?
Regards,
Matt
Regards,
Matt
On the same boat here... let me know if you have any luck  :-\
Delta Sigma said:
Strange, both Dany & Max's publicly shared dropbox files are suddenly dead links. I wonder if Dropbox changed their public link format.
Yes they did.
There's no public folder anymore.
The files are still there but Max and Dany will have to share them manually once more...
Some of the images are still interspersed throughout the thread - i will post them here for easy reference - one at a time so they stay on GDIY's servers.
Attached is the MK-U47 schematic.
same here, wanted to start building and all the pictures are gone  :-\
has anybody by chance saved them?
i wrote Max and he kindly sent me the pictures. So here you go
MK-U47 Tube Microphone Kit featuring:
Costum Headbasket made by Flea with Pattern Switch
Brass made body tube and bottom bell, bead-blasted and nickel-plated
Stainless internal structure
Bv.08 Transformer with 8 seperate sections from my own production
6028 single supply circuit with all parts including
including (back left to right):
body tube
bottom bell with power resistor mounted + internal structure
Headbasket pattern switch
Transformer + resistor board
High-Z board with screws, teflon isolators, shims for variable capsule mount height
solder lugs and subminiature reed-contact
Black rubber band for tube shock-mount
Tube deck + tube sockets, screws,
(front left to right):
Wiring, yellow wire sleeve, shrink tube
Binder connector for mic and cable
Bv.08 Transformer
PIO and styroflex capacitors, resistors
to complete the microphone, you'll need:
a capsule + holder
a single supply 105v PSU
a microphone cable (cable connector to mic included)
Completed kit with Flea capsule holder:
BUILD:
Schematic:
Wiring Plan:
we start from the bottom up.
Use small pieces of wire to bridge contacts as shown
wire the connector according to the original schematics
Solder a lug to the end of one black wire
1: White
2: Blue
3+4+6: Black x 2
5: Red
Unscrew this resistor
Solder yellow and red wire
use shrink tube for isolation
mount the resistor back in
unscrew the ring of the connector and place it
in the bottom bell, aligning the keyway/slot
carefully place the ring and tighten
unscrew the nut and place the solder luck and re-tighten
paint the transformer/resistor board (not shown: use a file after breaking)
Solder together the boards as shown, check for right angle
place and solder all resistors as shown
place and solder all wires as shown
Be careful handling the transformer
place and solder the transformer as shown
Before soldering the big capacitors it's time to mount the whole thing into the mic
insert the screws and attach the nuts, do not overtighten!
Place and solder the two green capacitors as shown
The yellow sleeve will be cut like this to fir through the hole
Carefully cut and drill (pierce) the rubber band as according to this measurements
unscrew these parts
mount the tube sockets, check for orientation!
bend and add a solder lug
attach and solder short black wire
Wire up as shown
attach the rubber band
mounting the tube deck
feed through the wire sleeve
attach the yellow, red and blue wire to the corresponding pins
Be careful with overheating when building the highZ portion of the circuit
bend and place the solder lugs as shown
a small wire bridge, do not solder yet
the reed contact must be oriented and placed carefully BE VERY CAREFUL HERE
do not bend the contact after soldering or i will break
you can hold the tiny contact like this for placement
to have free access, slide the middle lug away
the contacts inside the glass envelope must be oriented this way
solder second side only after orientation is correct
more wire bridges and placing parts, place everything before soldering, solder quickly
the teflon feed throughs
push the carefully to place, grabbing them by the top teflon part
solder the two black wires
mount the highZ board + spacer as shown
attach the wires to the teflon feed throughs
attach the rest of the wires
place the tubes
Shown with a Flea capsule holder
:D
Thanks Voodoobeat for re-posting the pictures!  Much appreciated.
I'd assume that your capacitor will be fine as they are both 10nf, but I couldn't say for sure about the voltage.
A  lot of the pictures just show up with little question marks - the recent reposted ones.
What happened to the original posts? I thought they would remain here at GDIY?
