evilcat
That's just beautiful!!!
Sample 1 to 7 where used in original Bv.08, Bv.11 and Bv12 transformers.
0dbfs said:Sample 1 to 7 where used in original Bv.08, Bv.11 and Bv12 transformers.
Max, Could you possibly be convinced to do a run of BV11's?
jb
Yes, absolutely, i will add this to my store soon, wound with 8 chambers like the original of course.
ioaudio said:>>This kind of alloys typically contains from 1-2% impurities.
No, more like (ballbark figures) >= 0.05% C , >= 0.005% P, >= 0.005% S and some 0.1%to 0.2% Si
>>Bv11 - Very cool! Possible to make sure they are size and pin compatible with Poctop's M49 PCBs?
The size will be the same as the original Bv.11 - the transformers used in poctop's pcb have a different size...
-max
ioaudio said:the pinout will be the same as the bv12 pinout minus the 4 outer pins - i will publish the bv11 pinout soon.
