rainton
Oh yeah!!
1. Talk to Andreas about his VF14er. Its the tube which can work in U47 without modifications.Rossi said:Pip, all new U47s had a VF14 tube. The nuvistor was merely a retrofit so users could use a commonly available tube. At the time many studios replaced tubes routinely *before* they would fail in order to avoid troubleshooting during a session.
Of course one of the main motivations behind the VF14 was the single voltage power supply. But that technique led to a quite unique circuit, and since that circuit is so simple, every one of its very few components plays some part in its sound. Apart from that, the VF14 is lower noise than most tubes. Also, there is the underheating aspect - few tubes can stand severe underheating for so long.
Andreas Grosser's FET retrofit seems like cool solution. To my knowledge, he doesn't sell it separately, though.
JW said:I imagine this question has been asked before. If so, can someone direct me to where it's been discussed.
Just wondering what the difference is between this transformer and the one Max was/is offering w/ the MK47 kit?
ioaudio said:Pip, i'm pretty shure that you mixed up something, both transformers are made by me.
The Bv.08c from the Mk47 Kit is made from the same lamination footprint, but lower stack height to fit the smaller housings.
My new Bv.08 is full size, full stacked height and wound on 4 seperated chambers per coil (eight chambers total) just like the original Neumann Bv.08.
Citrus Hill said:I'd like to get on the list for a pair of these if possible. Looking forward to seeing the finished product. Anything worth having is worth waiting for!
