untune
Thanks IanSchematic looks basically OK to me. Nothing missing. I would be tempted to double the smoothing caps values. Heater elevation looks OK. It should sit at one third the HT voltage. I typically set mine at one quarter the HT voltage but one third is just as good.
ian
Also found an alternative power transformer here but I might see if they can do the same but with a higher rated heater tap—I was thinking about experimenting with the 6BX7GT at some point down the line but it's hungry on the current and wants 1.5A to itself. With the ECC83 it'll add up to 1.8A
