thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
Is there such a thing as a 'slim line' multi-pole in-line connector (rectangular,10-20 pins), as opposed to an in-line connector that mates exclusively with a chassis-mount or PCB-mount connector?
I have seen - on vintage equipment - in-line connectors akin to D-sub connectors. However, they were plastic, so didn't have the weight of a d-sub. Something like this (i.e. lightweight) would be ideal.
This is for the purpose of signal distribution in a mixer (will keep to Faston for pwr and GND). Currently a lot of KK connectors are used for each PCB. However, if the mixer needs servicing, it's a total PITA to disconnect every KK. The whole thing is line-level / low impedance, so I don't think there should be x-talk issues if I consolidate the KKs into looms + multi-pole connectors.
Thanks in advance.
BTW - for example, something like a hard-drive connector (the Molex type), but with more pins, gold plating and better / ruggedness reliability over in / out cycles would be ideal.
Thanks in advance.
