EEMO1 said:hey!
got my board!
can you use something like a nady 460 psu for this? the only question I have, is can you use the mains transformer and just adjust the voltage with resistors? too much current?
Blue Jinn said:I'm not familiar with the Nady 460. If you mean the Apex 460? I am pretty sure the PSU has about 150-155v for B+. (Based upon what I have read, I have not tested it)
That is close to the maximum for the 5840 tube. This circuit is designed for a B+ from 95-120v (Orig Royer mod is 95-100, BigUgly's G7/Royer hybrid is designed for 120. ) This also gives you about 60v on the capsule.
EEMO1 said:I think calculating the resistors etc on your psu board... might work?
should work fine. just remember to calculate for wattage on your dropping resistor. more volts dropped the higher the watt rating of your resistor needs to be. I think I only put in enough space for a 5 watt resistor in the PI filter. If that isn't enough use two 5w resistors in parallel that are double the ohm value you need.
So, we need two, one that gives 120vac and one that gives 8-15vac.
Looking at a datasheet for the 5840 tube, the heaters draw .15 A at 6.3v (AC or DC). This means the heaters want 1 Watt. Because it is rectified first, you want your transformer to be able to supply extra power for the rectifier to throw away. Just as a ballpark guess, if the pre-rectified voltage were 12.6v, then (at .15 A), the rectifier would dissipate (12.6-6.3)*.15 watts, which is also 1 Watt. So a transformer > 2 Watts (or VA) would be what you'd look for. VA means Volt-Amp, which = Power (Watts).What VA ratings are enough?
telefunk said:What is the size of the PSU board, approximately?
Trying to figure out a case for it...
