Sorry about the lack of updates guys. Life caught up to me and had to take a little break but things are rolling along now. I've concluded all tweaks and testing for Rev 1. There's nothing left to improve/tweak at this point. Moving forward with Rev 2 and will ordering final prototype in the next few days. Production run is right around the corner. I put it on the master on a mix I'm working on last night - sounds amazing. I REALLY like those T1/T2 filters. Can see why people love them on the drum buss so much. Really smooths out the cymbals but doesn't squash the bottom end.
Changes for REV 2:
-Default mode is now Stereo Sidechain (SSL/Turbo) Mode.
-I was able to remove a chunk of circuitry for the bargraph - the ground sensing circuit. It was done for increased accuracy but difference without it is practically nothing. 1% resistors will have more of an impact on accuracy. That being said, now that I have some extra space I'm going to add a pot on each L/R/I/O channel so you can fine tune each channel individually on the bargraph. I'll also add extra pads so you can easily just drop in a fixed resistor if you'd like. Currently mine is set up with fixed resistors (although I hand select and hand match values) and accuracy between all 4 channels is within .2dB, but since YMMV, I figure the ability to use pots is nice.
-Wherever possible, I've tried to keep the swing on the pots to a minimum, so single turns should be sufficient for most places as they're about 1/10th the price as the multi-turns. I personally use multi-turns everywhere because I'm cool like that ;D, but it all comes down to whether or not you want to spent the extra money. The only place I say to absolutely use a multi-turn is on the power supply to set your +/-15V. That's not the kind of place you want to mess around. THD Trim would be another placer to highly consider, but not mandatory.
-Unfortunately, I am removing the toggle to switch between Gain Reduction Resolutions (10dB/20dB). Through my testing, I found it to be more annoying/confusing than useful. I tested a few different meters, and found that because of meter accuracy the closer you get to full scale, the accuracy is all out of whack between modes. And if you get one set correctly, the other is off. It's not any fault of the design, I'm getting completely linear current proportionate to the amount of GR, it's just any reasonably priced meter is going to only be so accurate as they're only so linear, especially the higher the needle goes.
-I've increased clearance around audio path Electrolytics so you can use up to a 6mm 22uF AE on the inputs, and a 10mm 100uF part on the outputs. I've also added a few additonal pads for different pitch parts on those guys. I know preferences vary greatly on what caps to use there, so it'll be easy to try whatever you'd like. There is also enough room to use Polypro for the bypass caps in the audio path.
-I've added provisions to be able to use a couple different types of Pots for Threshold/Makeup. It makes sourcing easier and doesn't leave you limited in case something's out of stock.
-Front Panels will be available in black alodine .125" aluminum with laser etched white engraving. They will be optional, but I will likely have to do preorders for them for the first run. Again, they're optional, if you don't want them I'm not going to force them on you. No preordering will be required for boards, of course you can if you want to to ensure you get yours reserved, but that's entirely up to you. It will be first come, first served.
-Below is a rendering of what the final front panel will look like. The offical name of this beast is now the SB4000, shadowbuss was just the codename until I figured out what to offcially call it. There won't be anything like ruckus328 written on the front panel, I wanted the name to be something that looked nice an professional, looked good in the studio, sounded like a piece of gear, and tied it in with my codename and the orginal. SB4000 does just that IMHO.
-I know you're all still waiting for pricing for this thing. I have been relunctant to set that until I am ready for production. There are a few reasons for this. One I'm still working on quotes, sources, and have yet to figure out what shipping costs will be. Front panels are a little tricky as they're 19" long. The other reasons I won't go into
I will have all that info in a couple weeks when the production run is ready. What I will say now is that it will be the best deal out there.
-On a somewhat sidenote, if there is an interest I will also probably make the power supplies available to buy standalone. They are backwards compatible with existing GSSL's if anyone wishes to use them for that purpose. They also offer an additonal fixed +12V supply rail for LED's relays, etc. Reality is, you could make this supply rail any voltage you'd like, up to 18V or so depending on XFMR used. You could even do that with my new design, if you wanted to make your relay's LED's, etc run off of..... say...5V. But you'd need to adjust the values on some resistors a few places. As default, I sized everything for 12V, so if you're not the adventurous type, just use the default values and everything will be fine and dandy.
Now for some pics!:
Front Panel final concept
Finished wired unit (I haven't chopped my lorlin shafts down so they're even with makeup/thresh yet in case anyone wonders):
And rough front panel (It's just a cheap vinyl overlay for my prototype so it's already starting to scratch and fray around the corners but'll give you an idea of what the final version'll look like.
